Hello,
I am looking to replace a pool heater which has not been used in years.
The heater being replaced is a Hayward H150.
I was doing some research and cannot seem to understand the definition of an "above ground pool heater " vs " in-ground pool heater".
The two models in the subject are the ones I am looking at, the H150 says above or inground, the Raypak description says above ground. Although, the Raypak pool suppliers say in-ground in the description along with some reviewers stating they are using it with an in-ground pool.
Aside from brand, price, and slight efficiency difference, they both are 150k btu.
Pool surface is 400sq ft.
We have direct sunlight about 9 hours a day and use the solar cover every night which has been pretty good and we are happy with, just would like to add a heater for a little extra warmth here and there.
So my question is:
Can someone help me understand the difference in a pool heater designed for in-ground and one for above ground?
Specifically, is there a technical reason from how the units are designed?
Thank you!
So my question is:
Thank you!
