Pool flooded HELP
Geaux Swim
8
Louisiana
Pentair Intellichlor IC-60
Recent rains have had flood waters over pool decking and into pool for
Days. It’s nasty swamp flood waters, pretty sure I have half inch visibility at best. Pool has been under water for four days now and it may take another 5-7 days before flood water recedes lower than decking. I’m trying to get a game plan as to how to recoup quickly so that the pool can be used to cool off from the major cleanup that will be required outside the pool.
I removed pump and heater to protect from flooding. I’m considering just installing pump and not heater initially until I get water chem straightened out. I tested the water and ph is currently in 6’s. I’m expecting the blue finish that once was will be yellow brown stained. Will be using and elevated chlorine along with PH in range help remove?
16x38 ft gunite pool 7.5 deep end
Variable speed pump, cartridge filter, heater, robot vacuum.
ajw22
28,524
Northern NJ
Texas Splash
33,415
Fiberglass
CircuPool RJ-45 Plus
Holy smokes!
Oh My God Wow GIF
Geaux Swim
8
Louisiana
Not sure about pumping out. Ground is obviously extremely saturated and high water table. I know it’s rare to float gunite pool but you can see how my luck has been as of late.
Reactions: Tena
ajw22
28,524
Northern NJ
I am not suggesting you empty the pool. Just pump it down to the normal water level.
Texas Splash
33,415
Fiberglass
Geaux, I feel for you over there. Did you check the pool for gators? :) The concept would be to use such pumps to help suck junk out a little at a time - like a trash pump. Then keep it topped-off for support. If the water is still at the decking you'll have to wait of course. But if it has receded, you will probably go through a relatively lengthy process of vacuum to waste, followed by a top-off then repeat. At the same time, you could try to keep a decent amount of chlorine in there, but wow, that's a lot of vacuuming and junk. It may just try to go green depending on how efficiently you can get the junk out, but do what you can. Be sure to post back with an "after" photo for this transformation. Crazy stuff there.
Texas Splash
33,415
Fiberglass
Also, don't forget to update your signature with all of your pool and equipment info. We refer to that on each post, and in your case, knowing your equipment is especially important.
Geaux Swim
8
Louisiana
Thanks. As bad as po is keeping out of house was successful and I’m certain that would have been 10x the headache as this pool.
Day before I lost pool pic 😢
HeyEng
836
Oklahoma City, OK
CircuPool RJ-60 Plus
Already some good advice, so I don't have much to add in that department. But, I did want to send my condolences...that is quite the mess. At least this isn't IN your house!!!
Geaux Swim
8
Louisiana
Some gave me HTC shock. Could I start water treatment with this?
Also I’m thinking with a cartridge filter I may be pulling filters many times an hour.
What your thoughts on a sump pump on bottom. Pumping a level out of the pool ( bad water) adding fresh water back, allowing to settle and repeat until enough junk is removed before starting pool pump and thus running through cartridge filters.
Another thought, Do they make a mobile filter system I could rent to get the bulk of solids out of pool before running my equipment?
Texas Splash
33,415
Fiberglass
Exactly what I was saying above. Just keep the pool full or with in a few inches. The shock is fine, but you better start shopping for some liquid chlorine. You'll need it for sure.
Reactions: Tena
Tena
177
Longview Texas
Pentair Intellichlor IC-40
It's still raining slightly NW of you. Hope y'all aren't still getting it.
Best of TFP luck!
(Yes use that shock your other levels are probably all down too)
ajw22
28,524
Northern NJ
I have seen such a rig that pool service companies have built to use for pool opening cleanups. You need to calla round and see who may have such a rig in your area.
TanyaK140
16
Houston, TX
Wish I could say we haven't been in your shoes before, but I cannot. This is our pool after Hurricane Harvey and my son in the kayak. The water level had already started to recede at this point. For reference, the spa is raised and sits about 12 inches higher than the pool. Stuff from the yard ended up in the pool, but thankfully no gators & not as much gunk as you appear to have. Once our power was restored, we just ran the pool pump continuously and dropped in a ton of liquid bleach. It took many days to get back to normal, however, given that the entire house was flooded, we had many other things to worry about it. We actually did not swim in it again until the following spring. We only had to replace the heater. All the other equipment just took it all in stride. Wishing you well on your journey!
Geaux Swim
8
Louisiana
24 hours into water treatment.
Started running robot vac today. 15 mins into cleaning.....
Reactions: allidb85
zea3
14,031
Houston, Texas
Dude! For a minute I thought you were about to start a crawfish boil! That is insane! If you have a pool rake try and net out some of those mudbugs so they don't clog up your robot. Were any of them alive?
CrystalRiver
648
Massachusetts
You know the polyfill-in-a-barrel rig for removing iron? Using that setup with the trash pump would help remove the larger (and living) solids without you having to replace the water.
Geaux Swim
8
Louisiana
Without being able to see the bottom we used pool net until we thought we had most of them out.
A couple really strong ones managed
To survive the bleach! As you can see pool has gone from swamp brown to green. Still adding bleach and cleaning cartridge filters every couple hours
