Pool fine all season then sudden loss FC
berddog123
45
Kansas City, MO
Just noticed cloudiness yesterday, looks like I need to slam. Has been up and running for 1 month in KC area
SWG pool, salt a little low, CYA very low.
Salt 2950
CYA 30
FC .5
CC 0
ph 7.4
Since CYA is low, do I need to get that up BEFORE I slam to at least 60-70? When do I add salt? I guess it's more a question of which order to work in.
Thanks!
mknauss
22,729
Laughlin, NV
SLAM Process prior to adding any CYA or salt.
Your chemistry is in a good place. Raise your FC to SLAM level (12 ppm) and start testing FC and adding liquid chlorine every couple hours. Once FC starts to hold, you can slow down to testing 3 to 4 times per day.
Once the pool is crystal clear, run an Overnight Chlorine Loss Test. Once you pass that, then add CYA and salt and return to normal maintenance operations.
Mr Bruce
2,438
Greenville, SC
Treat it like a non-SWCG pool until you finish your SLAM.
SWG off.
Leave CYA where it is.
SLAM until complete.
Then add salt (if needed. Verify with Taylor 1766).
Raise CYA and turn SWCG back on.
berddog123
45
Kansas City, MO
Thanks for the help to both of you. I got it to 12, kept it at 12 all day, was at 11.5 this morning, still has just a very fine "touch" of cloudy. Stay with the slam? or kick on SWG? We have forecasted thunderstorms all day and we have auto cover so it's gonna be hard to test today.
berddog123
45
Kansas City, MO
Lol, it was off yesterday all day but we are surrounded by cottonwoods and at times it looks like it's snowing! I test for CC everytime and the highest I have ever gotten is .5 ? Is that normal to never have any CC?
