Pool Evaporation
As was noted, wind is a huge factor. Relative humidity is another factor where you won't get evaporation when it's near 100% while in dry low humidity climates such as desert areas you get more evaporation. Water temperature is also a factor. The following shows how these factors come into play starting with a baseline of 85ºF water temperature, 80ºF air temperature, 50% relative humidity, and no wind at the pool's surface.
Variation of evaporation with wind
0 MPH .... 0.21"/day
1 MPH .... 0.31"/day
2 MPH .... 0.40"/day
3 MPH .... 0.50"/day
5 MPH .... 0.69"/day
7 MPH .... 0.88"/day
10 MPH .... 1.17"/day
Variation of evaporation with water temperture
70ºF .... 0.07"/day
75ºF .... 0.11"/day
80ºF .... 0.16"/day
85ºF .... 0.21"/day
90ºF .... 0.28"/day
95ºF .... 0.35"/day
100ºF .... 0.44"/day
105ºF .... 0.54"/day
Variation of evaporation with relative humidity
0% .... 0.37"/day
25% .... 0.29"/day
50% .... 0.21"/day
75% .... 0.14"/day
90% .... 0.09"/day
100% .... 0.06"/day (evaporation still occurs in this case because air is cooler than water so is less than warm water vapor saturation; if the same temp then no evaporation)
Variation of evaporation with air temperature
60ºF .... 0.29"/day
70ºF .... 0.26"/day
80ºF .... 0.21"/day
90ºF .... 0.15"/day
100ºF .... 0.08"/day
Based on this link for Toronto, I'll assume during the day 80ºF air temperature with 55% relative humidity and nighttime 65ºF air temperature with 90% relative humidity. If you are gas heating the pool to 80ºF, then with no wind the evaporation would be 0.14"/day during the day (0.98"/week) and 0.15"/day at night (this is typical where day and night evaporation is the same unless humidity gets to 100% at night and water comes out of the air as dew). With 1 MPH wind, it's 0.21"/day, with 2 MPH wind it's 0.27"/day, with 3 MPH wind it's 0.33"/day, with 5 MPH wind it's 0.46"/day. However, if you are using a pool cover, then there should be no evaporation.
Reactions: MonicaRenee
Is there a good calculator for evaporation rate as a function of the various parameters mentioned?
I was in another thread where the OP was asking about salinity increase due to evaporation and high salinity fill water. It would be nice to be able to point folks towards a calculator if one is available.
not sure why that would really be helpful? the main issues with evaporation, especially fast evaporation is people being concerned about having a leak. that is easily confirmed with the bucket test. as far as a calculator, not sure how helpful that would be, being that humidity, air temperature and wind speeds are so variably over a 24 hour day. you just wouldn't get great results. if your bucket tests confirms 1/4" per day, etc, that what it is. it really doesn't matter if you use a calculator and determine you "should" be getting 1" of evaporation and really get 1.5". if there is no leak, then you are losing 1.5" to evaporation :) no biggie.
as far as figuring out salinity increases, that's pretty simply. if you have an average depth of 4 feet in your pool, and you lose 1" that's 2% of volume decrease. so everything increases by 2%. 3500ppm salt becomes 3570ppm. negligible, and not within the range of testing. its the same issue with rain , the increases in total volume of the pool is so small its negligible
as far as someone filling up the pool with high salinity water, not sure on that thread, but that can be calculated pretty easily too. all you need to know is how much each inch of pool water is on a percent of the pool volume. if you know the salinity of the water being added, you can calculate the total increase in ppm per inch of water refilled. evaporation really isn't a factor in determining that, just the total volume added each time and keeping a running tally of salt ppm. but again, I don't think that is a very common practice at all.
Thanks for the post. I agree that there are certainly rough, ball park figures you can calculate but my original question had a different intent. Perhaps I will ask it over in "The Deep End" forum as opposed to cluttering up this thread.
