- Jan 15, 2010
- 42
- Plaster
- Pentair Intellichlor IC-60
I do have an overflow - but appreciate the observation.Looks nice and neat. Is there a way to drain water? I don't see an area where you can connect a vinyl hose to in order to drain water if needed. You may have an overflow built in in which case no big deal (a pump would be used for larger volumes of water drainage if needed).
I did not know about the 12" straight Pipe. Any link to a spot where I can read about that?. Thank you for the observation.You should have 12" of straight pipe before the SWCG. ORP does not work in a residential, outdoor pool setting.
Intellichlor manual. Page 5 on mine.Any link to a spot where I can read about that?.
"ORP does not work"...... So the probe cannot be outdoors? not sure I understand why the probe would not function?You should have 12" of straight pipe before the SWCG. ORP does not work in a residential, outdoor pool setting.
Revised following input Not 100% but directional improvement made Almost 3 feet from Heater, SWC Vertical 10 inches straight before SWC By-Pass for heater and by-pass for SWC. Thank you to TFP members for the guidance.Does anyone see issues with this setup? The 2 T -Joints between the filter and heater are for ORP and PH Probes.
Thanks
Thank you - will get that setYou need to have a check valve on the output side of the heater before the T. As it is now your bypass will work as long as your heater holds pressure and does not leak. If your heater leaks and does not hold pressure without the CV water will flow through the bypass and back into the heater output and out the leak.
Heater Bypass - Further Reading
www.troublefreepool.com
