Pool Electric Timer
pmsmith2032
163
Northern Illinois
I have a GE Time Switch that I am having issues with. For the past few years it has been making a loud buzzing noise when on the "Timer" setting and the timer actually "on" (didn't make any noise when switch was "ON".. This year the electric is on when on all three settings ("On", "Off", "Timer") and it doesn't matter if the timer dial is in on or off. Also, it is still making the buzzing when the timer dial is "on" but no buzzing otherwise. Any ideas what could be wrong?
ajw22
24,727
Northern NJ
Pentair Intellichlor IC-60
Probably fused relay contacts. Replace it.
Bama Rambler
24,201
It's most likely the clock motor making the buzzing. You can pull the plate off and see if everything is tight, but it's most likely time for a new timer.
ajw22
24,727
Northern NJ
Check that the power is off to the wires using a mutimeter or current tester before you touch the wires.
pmsmith2032
163
Northern Illinois
Thanks! How difficult is it going to be to wire a new timer from a different manufacturer? I can do some wiring (like replace light switches) but don't have a lot of knowledge with complex wiring. Here are some pictures of what I currently have.
Bama Rambler
24,201
You shouldn't have any problems wiring another brand of timer.
1) The black wire to the left is incoming power it will go on clock power of the new timer.
2) The black jumper connects power to relay 1 common. it'll do the same thing on the new timer.
3) The white wire is neutral for the clock power. Apparently neutral is ran directly to the item the timer controls.
4) The black wire under the NO terminal goes to the device controlled by the timer. It will go under the NO terminal of the new timer.
