Pool dug in wrong spot
Worm7011
16
Maryland
New member here. Just had a pool dug and excavator misread the plans... it’s off about 8’. It will now put one pool wall in the middle of the dug pool without virgin compacted dirt against it. What’s the proper way ensure the new wall is supported correctly and long lasting?
PoolGate
5,235
Damascus, MD
Jandy Aquapure 1400
Need to know what type of pool - fiberglass, gunite, etc. Also pictures would help.
Worm7011
16
Maryland
Gunite. For argument sake, the pool was supposed to be dug 18’ from the corner of the house, They only dug it 9’. They are now going to have to dig out another 9’ over over in into the dirt and frame up and pour a wall in what is now the center of the pool. I’m assuming form the wall and backfill. Not liking this as a back filled wall can’t be as strong and a virgin soil wall.
ajw22
22,155
Northern NJ
Pentair Intellichlor IC-60
The builder should put 3/4 clean gravel in to build up the overdug areas back to the level required. None of the soil should be put back in as fill.
What does the builder propose to use as fill?
@Rich D @jimmythegreek @bdavis466
PoolGate
5,235
Damascus, MD
Jandy Aquapure 1400
Can you post a picture of the hole? It would help to get an idea of what your ground looks like. It is always preferable to use undisturbed ground but builders build in disturbed ground all the time. If your builder is competent, it should not be a problem. Make sure you understand your warranty, especially the shell warranty. If it is lifetime, understand what you need to do should there be an issue and what happens if the builder goes out of business.
Neto
290
Puerto Rico
Just complain to your pool builder and let him know that that is not what you and them agreed. They should fix it..
spd500
564
Houston, TX
We have several members here that are more educated as to proper fill around your pool, but personally I would want the contractor to have the project bonded after such a big mistake had been made. A lifetime warranty is great to have, but will not do any good if the contractor goes out of business. Having the project bonded is usually not very expensive and will protect you in the even that you do have issues later and the contractor is no longer in business.
Reactions: duade
spd500
564
Houston, TX
I am sure they will offer to fix it, but knowing the proper way to fix it is very important in a situation like this. Without the proper fill the pool shell or decking can fail and leave the owner with very expensive repairs.
Reactions: revitup
jimmythegreek
In The Industry
Aug 10, 2017
3,176
Morris Cnty NJ
They can frame it amd shoot against it. Hopefully the depth is right. If not proper prep with base stone is critical to long term quality. Sounds like its deep end that has to shift to new area so that's gonna require stone to fix the deeper area for shallow depth. Make sure they dont skimp amd use dirt for fill. Nothing but stone
Worm7011
16
Maryland
This was the side they compacted in 8” lifts and then came home today and they sprayed it with something and it was falling in on itself.
Sollace
465
Bryan TX
Just a comment here -- When our backyard was measured out and the outline for the pool laid. . . .One of them mentioned they started a dig and the homeowner changed their mind with the location. It can happen. Your pool builder should work with you. What you want is on the plans, it's in the contract, they comply. Keep us posted )
Worm7011
16
Maryland
Yes. They admitted it and attempted to fix it. The backfill was dirt compacted in lifts... this is today, no rain.
jimmythegreek
In The Industry
Aug 10, 2017
3,176
Morris Cnty NJ
They compacted dirt with what machine in 8" lifts? Looks like they tried flashing the shell and failed miserably. What type of soil do you have there
Worm7011
16
Maryland
Apparently good compaction soil is what they told me (I do believe this). They fillled, tamped and then clean cut the edge w the excavator.
They used their bobcat and one of those vibrating tamping machines (person pushing around like a lawnmower). I do know they were doing this section all day... approx 7’x51’
question is, what should of been done?
was told this am “this is more compacted that the fresh cut, you’ll never have settling problems” and then I come home to this unaware. Poor communication doesn’t ho the matter.
jimmythegreek
In The Industry
Aug 10, 2017
3,176
Morris Cnty NJ
I cant really say what should have been done without being there myself. I will tell you that the average walk behind compactor can do 3" lifts max. They may feel its tight, but without proctor density testing it's all a guess.
The foundation of any structure is the most crucial aspect to get right. Everything else depends on it
ajw22
22,155
Northern NJ
What should have been done? Fill the dig up to the needed level with 3/4 clean gravel. That would ensure you have a stable foundation for the pool.
I would insist on a soil density test - Proctor Compaction Test: A Basic Guide and a soils engineer compare the compaction of the filled area to the undisturbed soil. If it is equal or better then you are good. If not then dig out the fill and put in stone.
Reactions: jimmythegreek
Like Trouble Free Pool?
Support us with a donation.
