Pool Dig soon......
MARV19
21
Wesley Chapel/ FL
Hi All,
Our pool dig will start soon. As this is my very first pool, I want to make sure that I understand everything as much as I can. I learned a lot and still learning from this forum. Here are the details:
Pool Features:
44’ X 25’ rectangular pool
Pool Depth: 3.5’ to 6’
Shallow end Sun shelf: 25’ X 9.6’ (25’ will have 7’ X 7’ 360 deg. SPA sitting on one side) with 3 LED Bubblers
Deep end Sun Shelf: 20’ X 5’ – (2 LED Bubblers, plus a Step Pad )
12’ X 6’ wall with 8’ rain fall or rain arc water feature
4 wall returns; 2 floor returns at the deep end (to heat the pool fast)
1 skimmer, Overflow protection-Yes, Autofill-Yes, Screen Enclosure-Yes
SPA Features:
7’ X 7’
Integrated with pool, 12” raised from shallow end Sun shelf
360 degree infinity spa
6 therapy jets
1-main drain
2 -floor returns
Equipment:
All PENTAIR
2- pumps (1 for pool & spa -IntelliFlo VSF; 1 for water features(bubblers & rain fall)
QUAD DE 60 filter
400 K BTU Natural Gas Heater
IntelliChlor IC60 with SWCG
Automation:
Intelli Center System
load center with I8PS Personality Kit
Questions:
Do I need more returns for better circulation?
Do I need side suctions or add 1 more main drain in the deep end?
Do I need anything to add more for SPA?
I want to automate Pool, SPA ( including 360 spill), pool & Spa lights, Bubblers, rain fall water feature and its light effects. Do I need to upgrade I8PS to I10PS?.
Plumbing:
Based on my very basic understanding I came up with my own pool plumbing schematics. Please refer the attached PDF documents and please provide me your suggestions, corrections to my errors.
Thank you
  • Pump1_plumbing.pdf
  • Pump2_plumbing.pdf
YippeeSkippy
16,012
Evans, Georgia
I'm a tad disappointed that a pool that large is going to be so shallow in the deep end. No diving, cannon balls hitting bottom, BOO HOO!!! :cry::cry::cry::cry::cry::cry: I could cry for the missed fun.
Be sure to specify that your depth measurements are the *water depth* and not the pool wall height. Some folks have missed that little issue and later been very disappointed.
Pentair ☑️ except tell us *which model #* so our Pentair experts can chime in on best ones for you.
You need at least 2 skimmers* for that size of a pool.
Maddie :flower:
wireform
In The Industry
Aug 15, 2017
2,107
Spring Valley, NY
Have your skimmers and main drains each separately plumbed direct runs for better control and incase of a problem in one skimmer it can be valved off without effecting the other or the main drain. Make sure not to undersize suction side pipes.
