Pool cover holes
Belluca
13
Matawan nj
I have an in ground pool with a tarp-like cover. Now that the snow has melted I’ve noticed a bunch of holes and tears in the cover. When i attempted to pump the water off of the cover i wound up pumping pool water out as well. The only idea i had so far was to switch from water bags to bungee cords in order to try and get the cover as tight as can be. Before i pump water out of the pool by accident i was wondering if anyone else had a better idea.
Thank you
ajw22
24,588
Northern NJ
Pentair Intellichlor IC-60
Forget about the pumping and just pull the cover off when you are ready to open the pool.
Reactions: duade
Newdude
6,804
NY
It wouldn’t hurt to SLAM the above water before it gets dumped into the pool water. You will be FC-ing it either way, might as well get a head start.
