Pool Coping Caulking
coachhim
91
Oklahoma City, OK
Hello. We moved and have been in this house with the pool about 4 years now. Now the caulking around the pool is starting to come off the edge.
I have seen on youtube people putting caulking filler or backer in the grove then using a self leveling caulking to fill in the gap. My question is my old caulking looks more like silicone and looks as if it has grits of sand on it.
What do you guys recommend in doing this??
Thanks!
ajw22
28,524
Northern NJ
Pentair Intellichlor IC-60
I think you are asking about the flexible mastic that is in the expansion joint between the deck and coping. However there are different forms of pool construction so if you can post some pics of your pool and deck and the area we are discussing it would help.
coachhim
91
Oklahoma City, OK
This is one of better spots. But it's separating at other places
ajw22
28,524
Northern NJ
I need to see some wider shots to see the deck and coping.
coachhim
91
Oklahoma City, OK
Is this better?
ajw22
28,524
Northern NJ
I think you posted your reply in the wrong thread...
But your expansion joint looks fine to me. I don't see problems requiring all the work involved in redoing it.
You would need to scrape out all the old mastic down to the ground. Some folks use an oscillating tool for that. Tape along the sides of the joint.
Then put foam backing rod in the joint and fill it with Deck-O-Seal or Sikaflex.
Have good knee pads.
Reactions: coachhim
