Pool company opened and forgot skimmer parts...please help!!
Mlt153
4
Harrisburg, Pa
My pool has 2 skimmers. The pool company opened it yesterday but didn’t put these parts in the skimmer (which aren’t working great at the moment). I have tried to locate the parts online to get an idea of where they go but no such luck. Does anyone know where these parts go? I have a hole in the back, bottom and front of the skimmer. Thanks!
Jimrahbe
15,063
Bedford, TX
153,
None of those parts look like something that goes in the skimmer to me... :scratch:
Let's see if anyone else recognizes them...
Mlt153
4
Harrisburg, Pa
Thank you, last year was our first year having it opened and the builder did it. I am pretty sure the parts were from the skimmer...the pool company mentioned skimmer returns and not liking them so maybe these parts have something to do with that?
Jimrahbe
15,063
Bedford, TX
Let's see if we can call in some help... @JamesW
I looked again at you pics and I think you are right... I think your skimmer uses the return water going through the "jets" to create a jet of water... I have no clue how the work, but I bet JamesW does...
JamesW
16,766
I don't know about that skimmer.
Is there a basket?
Are there any part numbers or names on any of the parts?
Mlt153
4
Harrisburg, Pa
Yes it just uses a regular skimmer basket. There is a hole under where the basket sits, one behind and one to the front that goes into the pool (in case the picture isn’t clear). No part numbers unfortunately. It’s an Anthony Sylvan pool built on 2017.
PoolguyinCT
In The Industry
Jul 21, 2014
3,083
Connecticut
Looks like a plain old Venturi skimmer in OP parts post?
Doubt AS would spring for a quality unit, probably a paramount knockoff.
Regardless they all work the same, see above guys post.
Mlt153
4
Harrisburg, Pa
Thank you so much, that makes sense and I really appreciate your help! I have reached out to A & S but they are in no hurry to get back to me so it’s nice to have this wealth of knowledge:)
PoolGate
3,887
Damascus, MD
Skimmers often come with 2 holes. One that goes back to the suction port of your pump and one that goes to the drain. On these style skimmers, there is usually a flap mechanism that allows the skimmer to move between the floor drain and the skimmer function (large opening). Mine has this but it was not used as my floor drains are home-runned back to the pump. I had parts similar to what you have but was instructed to toss them. If only one hole in your skimmer is being used, your skimmer only needs the weir door and the basket.
ajw22
11,287
Northern NJ
@Mlt153 has a venturi type skimmer. Not the type you describe that controls a main drain. She should not toss the parts. A venturi skimmer has both skimmer suction and a return on the same unit. The parts are needed for the return and venturi functions to work properly in her pool.
