Pool company guy screwed up...
Pperc15
205
Philadelphia
Help, I’m doing something wrong. I tried to take my pump lid off after I thought I closed things properly, but of course I hadn’t and water started rushing up out of the pump. What did I miss? Pictures attached.
Pperc15
205
Philadelphia
Got the lid on, but lost a lot of water from my spa. I guess somehow I had the spa drain open?! Ugh. Refilling the spa now with some water and then going to let circulate for 30 minutes and retest chems. I feel like an idiot but don’t know what I did wrong.
Before someone asks, pool pump is below water level.
kimkats
42,132
Tallahassee, FL
That water does look good! Well done!
:shock: what??? Oh no! "How do I make it STOP???" was the thought bubble over your head I bet!! I am glad you got it back on. Now to figure out what valve was not turned the correct way. I am guessing it was the one in the third pic. I THINK the off should be pointed away from any pipes. I will ping someone who knows about these kinds of valves for you.............Allen!! OH Allen! @ajw22 HELP!! please!
Reactions: Pperc15
Pperc15
205
Philadelphia
Thanks, but the reality is that the pool company has the water looking that good, not me. Despite the chem levels not being TFP optimal.
Yes, I was not so happy. Took some force and finesse to get everything back on while water was gushing out. Not to mention the o ring is probably stretched out because it didn’t want to stay seated properly in the cap! Lost quite a bit of water from the spa (which is the pipe in the third pic at the bottom).
Reactions: PoolguyinCT
ajw22
11,263
Northern NJ
Don’t open the pump lid when in spa mode and then close Valve 1 before @Pperc15 opens the pump lid. Make sure you open Valve 1 before you turn on the pump. The risk of closing Valve 1 is you forget to open it which can damage something.
Pperc15
205
Philadelphia
I’m not following. What should the handles be set to? How do I close valve 1? The off can either be facing skimmers or main drain....
ajw22
11,263
Northern NJ
Yeah, you have a stop on the handle to prevent you from putting OFF over the input pipe. But then PB did not fully think through pump being below the pool. You can cut off the stop on the handle that prevents the turning as long as you understand the risk. You can always buy a replacement handle if you want to restore the stop.
Pperc15
205
Philadelphia
D
Seriously? So every time they were emptying my pump basket they were allowing water to gush out? Wtf. Is it likely they would just come and back wash each week and not empty the basket / open the pump lid? That’s kind of insane.
mknauss
22,749
Laughlin, NV
You will have to take the actuator off and then use the handle to point the off towards the pump. That will eliminate the water flow to the pump.
Reactions: Pperc15
ajw22
11,263
Northern NJ
My suggestion accomplishes the same thing and does not require removing the actuator every time the pump basket is opened.
Reactions: Pperc15
ajw22
11,263
Northern NJ
D
Pool guys are used to dealing with water gushing out. Remove the lid, pull the basket out quickly, get the lid back on, clean the basket, repeat to install the basket back in pump.
Reactions: Pperc15
