Pool chemistry question
PammyB
14
Hudson, Quebec
Am I done balancing? I'm confused about what acceptable TA and CH numbers are and if the CC of 0.9 is a problem?
Water is clear, what should I do now? Thank you!
FC: 4.5
TA : 102
PH : 7.5
CH: 166
CC: 0.9
Texas Splash
39,558
Fiberglass
CircuPool RJ-45 Plus
Can you tell us what test kit you used for those numbers? The K-2006C would not provide a CH and TA of such numbers. By the way, CH is really "N/A" for you with a vinyl; pool unless it skyrockets too high (scale). Can you also tell us your CYA?
PammyB
14
Hudson, Quebec
Sorry I did a pool store test in addition to the Taylor test and they were almost exactly identical, those number are pool store's but they match what I got at home.
TA is approx 100, do I need to raise it?
CYA is 30
