Pool build Vineland NJ
Dapdo
60
Vineland, NJ
#1
So excited to receive our contract! Now to get hoa approval (eyeroll) and city permits.
Details:
18x42 hamptons style gunite rectangle
3.5'-6.5'
28000 gallons
8x10 sun deck with bubbler
French grey diamond brite
All 2" and 2.5" PVC piping
Pentair quad de filter
Pentair intelliflo vs pump
Bonding and electrical included
Ez touch 4 with screen logic 2
2 skimmers
2 intellibrite color led lights
Supermesh safety cover
IC40
1' bluestone coping
4 pentair deck jets
:D
ajw22
3,242
Northern NJ
#2
Get an IC60 SWG. We recommend your SWG capacity be at least 2X your pool volume.
Good luck. Pictures of the pool build are always appreciated.
Gorilla83
308
Thornton, PA
#4
Sounds like a really nice build. What are you thinking of doing for decking? Any thoughts of going with an autocover? I know if we were going with a rectangle I’d really consider one.
Jimrahbe
10,520
Bedford, TX
#5
Dap,
Make sure that they don't try to give you the EasyTouch "Lite".. Model number will have an 'L' in it like PL4 or PSL4..
You want a real EasyTouch like this one... https://sunplay.com/collections/pentair-easytouch-control-systems/products/pentair-easy-touch-control-system-520593
This assumes you will NOT have a spa... We always recommend a cell that is at least 2 x the volume of your pool. This makes the IC40 a little small for the size of your pool, but being in NJ you will not have the same issues that people in Texas, and AZ have.. :p
The unit above comes with a built-in SWCG power supply.. When the IC40 needs to be replaced, you can just buy the IC60 cell.. Or if you are flush with cash, you can get the ET8 which comes with the IC60... https://sunplay.com/collections/pentair-easytouch-control-systems/products/pentair-easy-touch-control-system-521150
Also makes sure your IntelliFlo pumps does NOT have the SVRS option.. Don't fall for the "it's required routine" it is not...
Dapdo
60
Vineland, NJ
#6
The estimate for the autocover was 18k installed so no autocover lol.
Re decking the pool is going in next to a 500sqft paver patio so we aren't doing any decking, just coping.
Dap,
We are getting the ez touch with integrated salt water generator. Our builder does not recommend adding salt for first 6 months so we are waiting on adding the swg until we can use it to get the most out of the warranty
jimmythegreek
423
Succasunna, NJ
#7
U r gonna have to do decking it's gonna get trashed w the pool install u will be re using ur pavers I guess but in the end u will need some to make cuts to fit unless u shrink the deck a little and cut into the existing edge w coping
kimkats
35,961
Tallahassee, FL
#9
I am in to watch this one! It sounds great so far! I can't wait to see some pics!
Plaster pricing-depending on your PB. Some say this and others may say that. Best to ask your PB on this one.
Kim:kim:
Dapdo
60
Vineland, NJ
#10
Going to be a while to get through permitting. Some towns around here are ridiculous ie need 2 engineers to sign off on the plans but I think my town is reasonable just slow.
I'll try to get some before pics of the yard
kimkats
35,961
Tallahassee, FL
#12
I can't read the words but I like what I see in the drawing. What are the walls/benches around the pool?
What kind of depths are you thinking of?
Kim:kim:
Dapdo
60
Vineland, NJ
#13
Kim:kim:
We intend to surround the pool with a boxwood hedge and a limelight hydrangea hedge behind that in true hamptons style. We are doing 3.5 to 6' at the deepest.
Dapdo
60
Vineland, NJ
#17
Most of nj is a pain. U prob misunderstood the requirements they want 2 sets of stamped engineered drawings when u apply not 2 diff engineers. Typical of any structural work
Nope. Two engineers. Pb told us it costs people in that town thousands of dollars to get permits through. Apparently very litigious.
Dapdo
60
Vineland, NJ
#18
Been a little while since I posted but, the pool is dug, gunite shot, back fill is done. Everything went great, our PB has been awesome. I guess we are waiting for spring to finish. We have one big decision left to make and im completely torn: coping.
Our estimate has 12" bluestone tread coping, no decking we were going to surround it with lawn like a hamptons style pool. The pool is 6 feet from a 420 sqft patio.
For the cost of the bluestone treads, I'd be able to do stamped, stained concrete, 3 feet of decking and another 300sqft patio.
What do I do?!
kimkats
35,961
Tallahassee, FL
#19
If the grass is going to be real then NO to the grass! You will thank me every time you don't have to worry about the grass in the pool from feet or the mower! If you can do fake grass then go for it but get the good stuff!
