We have a build that we are planning for that should be ready to break ground late March/early April. We've interviewed about five different PB's and finally settled on one. Now it's time to get in the weeds. We have a 14 ft easement we are up against, so the pool will be bit narrow. I've attached the design, but we still need to pick out the coping, tile, and decking. Since we have a few months ahead of us, we have time to settle on choices, then change our minds, then settle again!
After browsing this forum, I've concluded that we want to go with a saltwater pool. I told the PB that I wanted IntelliCenter to control it, but for some reason they quoted "Intellicenter 8 With Ez Touch - SCG Bundle (salt cell generator)". I'm not sure how Ez Touch fits into the IntelliCenter system. Looking for some feedback from the folks here to help steer me in the right direction.
I'll be sure to track the build on here as we start breaking ground.
Here is the list of items that was included in the quote. Anything we should add or change, please let me know.
Swimming Pool Specifications
Perimeter: 115'
Max Width: 14.5'
Depth: 3.5/5/4
Area: 478'
Max Length: 46'
Volume: 12.5k gallons
STEEL REINFORCING :
Beam – four bar box beam #4 steel
Floor and walls - #3 steel 10” on center
POOL/SPA PLUMBING :
ALL POOL/SPA PIPING INCLUDED:
MAIN PUMP: 3HP Variable Speed Pentair
MAIN DRAIN: Pebble Top A&A
RETURNS: N/A Use Infloor
FILL LINE: Auto Fill
FILTER: 420 Clean & Clear Cartridge
SKIMMER: (2) Ultra Skim A&A
CLEANER: Infloor Cleaning System ( full )
HEATER: A 400K BTU MasterTemp Pentair
ADDITIONAL SPECS INCLUDED AS FOLLOWS:
All Dedicated Suction
(2) Common Returns For Spa Spillway
1.5 HP WhisperFlow WF Pump For Bubbler & Sheer Decents
(2) 1' Sheer Decents On Columns
(1) Bubbler On Tanning Ledge
Spa W/ 6 Hydro Theraphy Spa Jets and (4) Air only foot jets (1.5")
GUNITE SHELL:
PNEUMATICALLY APPLIED GUNITE PER CODE
OWNER TO WATER CURE TWICE A DAY FOR SEVEN DAYS
ONE SET OF CUSTOM STEPS IN SHALLOW END
BENCH(S) ____1_____ QTY _____18’______ SIZE(S)
TANNING LEDGE: Yes
RAISED WALLS: Yes
HEIGHT AND LENGTH OF ALL RAISED WALLS :
(2) Columns Per Plan Raised 18" (2'x2')
28.5' of 6" Raised Wall Per Plan
10' of 12" Raised Wall Per Plan
7x7 Inside Spa With 7' Open Tile Spillway Raised 6"
ADDITIONAL SPECIFICATIONS INCLUDED AS FOLLOWS:
(4) MicroBrite Color LED Lights 12V In Pool
(1) MicroBrite Color LED Light 12V In Spa
(2) 100 Watt Transformers - Spa Light to be on separate relay from pool lights
Pre Wire GFI Light Above EQ PAD for Client to supply bulb
Intellicenter 8 With Ez Touch - SCG Bundle ( salt cell generator )
4' rectangle fire pit (PB stated they would not automate???)
Standard Maintenance Kit pole, brush, net, test strips, 5 lbs. 3" tabs 4 lbs. stabilizer
Startup And initial Chems
Pool School
30 Days of Maintenance Included
Perimeter: 115'
Max Width: 14.5'
Depth: 3.5/5/4
Area: 478'
Max Length: 46'
STEEL REINFORCING :
POOL/SPA PLUMBING :
GUNITE SHELL:
TANNING LEDGE: Yes
RAISED WALLS: Yes
Pool School
