I do not know a lot about pools, learning. My pool ran great for a month. I have a 17000 ig. The equipment was installed very high so I do have issues stArting it. I try to not turn it off. My current problem: air bubbles out of jets and noticed lower pressure but the filter tank jumped in one night to 20. Runs at 12. Yesterday I added a tab to chlorinator and hooked up manual vacuum. I normally use a swim vac top so that I can collect stuff in basket. The last few weeks while running vacuum , air bubbles started coming out. Only while vacuuming. So my swim vac top is old. I tried just using hose directly in skimmer . No bubbles . Thought all was good until this am when I found bubbles and pressure problem.
I raised my water level. No change. I have put the chlorinator top on again, no change .
I have used a pool sock so I really don’t think it needs backwashing. I did bump it , didn’t drop.
