So now what do y'all use to keep water clean and crystal clear? All summer long?
Well now, I'm so glad you asked. You need a reliable test kit first and foremost. Without a good test, just dip your finger in and taste it. You'll have about the same chance of getting it right. So order up a TF-100 from tftestkits.net. the speedstir is an awesome add too. It does all the mixing for you so you can focus on getting the drops right and properly counted.
From there with your results we will send you to get cyanuric acid (CYA), muriatic acid (MA), chlorine (bleach) and maybe baking soda. You plug your results into
PoolMath (or download the free app)
It will tell you how much and of what to add. We will guide you as much as you need.
You will test and add daily at first, and probably for a while. You will eventually become one with your pool and can easily stretch testing every other day and sometimes every third day. But it takes time to get there. Its easy peasy until then.
