Polaris pressure cleaner question
jonredraider
15
Austin, TX
Regarding the white float bulb on the back of the vacuum should it be empty and hollow or when I shake it should there be some water inside? My unit is pretty much brand new but when I shake it it seems already half filled with water somehow.
Jonathan
ajw22
25,667
Northern NJ
Pentair Intellichlor IC-60
What model Polaris cleaner do you have?
My white float is sealed and gets no water inside of it. I suspect you have a crack in yours. Maybe you can drain it and patch the crack. Otherwise replace the float.
jonredraider
15
Austin, TX
I replaced the float. 7 bucks. Seems to be behaving better now. Thanks.
Reactions: ajw22
