I have 1 timer on my pool. The Timer turns on and off the pool pump. It is wired so it only allows the booster pump to run if the power is on to the pool pump. So I can leave the Polaris booster pump power in the on position and when the regular pump turns on power is supplied to the Booster pump and it runs.
The down side to this is the booster pump will run the entire time the regular pump is on.
All I really need is for the Polaris to run 2 hours a day.
so the booster pump on off switch only receives power when the pool pump is on.
I cant add a traditional timer, because it wont be powered for the timer to move.
is there a timer or switch that will cut off after an hour every time it is powered on?
