- Apr 16, 2020
- 26
- Plaster
- Pentair Intellichlor IC-40
Hi there, I'm dealing with an issue where my 280 is only making right turns and getting the hose all pretzeled up. I'm trying things in stages, starting with the easiest and I noticed the front tire wasn't engaging with the small middle wheel and that the tire was really worn down, so I swapped it out with the back tire since it was in much better shape. Now, it just makes right turns but with a lot more confidence. The other thing I noticed is that the back wheel is very wobbly and I couldn't tighten the screws on the axel mount, so I've just ordered a whole new axel mount.
The thing I'm unclear about is how it's supposed to work... are both the front and back wheels supposed to be touching the middle wheel? Because the back one isn't anywhere close, which I can probably fix when I remount it and put a new tire on it (I also ordered one of those). But I just want to make sure that the expected behavior is that both the front and back wheels are touching the small wheel, because I've seen both referenced as touching it in my research but not both at the same time, if that makes sense.
Heather
Heather
