I'm in Dallas Tx and survived the freeze! All of my pool equipment seems to work fine except the Polaris 280 cleaner with Polaris PB4-60 booster pump. The cleaner is not moving at all. I disconnected the cleaner hose from the side of the pool. There's a weak stream of water coming from the pool outlet. The weak stream is the same whether or not the booster pump is on. That tells me the booster pump is not working. Because I can feel the stream from the pool outlet, I assume that water is flowing to the booster pump. If not, I shouldn't feel anything from the pool outlet where I normally connect the cleaner hose. Correct assumption?
When I turn on the booster pump, I can hear and feel the pump vibrating so there's power to the pump. Any suggestions on how to troubleshoot the pump?
Corey
Corey
