I have another post under everything else but was not sure how to move it here. quick question slightly different than that post:
1. if the plumbing is encapsulated in the gunite pool, can there be a leak in that plumbing in the concrete? if so, how do you fix it?
2. I have a presumed pressure side leak, was wondering if any of the liquid fix a leak (or similar) works? I am losing about 500 + gallons a day running the pumps for 12 hours. I can dig up the lines from the pump to the pool wall somewhat easily (better than going through the concrete deck) but would that be the likely area of a leak if he piping is all into he concrete and the pool does not lose water when the pumps are off?
thanks
thanks
