I have a swimming pool which works with an all-in-one pump/skimmer/filter/ladder which is housed in a hole next to the pool with the half with the ladder, skimmer and inlet pipe hanging into the pool. I can't even find out what such a contraption is called. It's over ten years old but still works. It's an old version of this: https://www.desjoyaux.co.uk/images/large/gri3.jpg
There's a crack along the width of the pool with water going into the hole which houses the pump part of this contraption and while fixing it I found that the water and chlorine has damaged the concrete between the pool and the hole, so I'm now removing a lot of it an going to replace it all with fresh concrete. As a part of this job I want to fill in the hole and set up a more modern pump/filtration system.
I can't work out what's the best way for me to do this. I can think of 2 options:
1. Having pipes going into the pool externally as seen here: Installing a new skimmer in existing in ground pool.
2. Taking advantage of the fact that I have the hole (about 1 foot deep) which housed the pump which I'm about to cut through to the pool to replace the concrete and insert a skimmer and an inlet pipe there. The inlet and pipe would be right next to each other which might not be ideal, but that's how it worked with the all-in-one system.
I don't have the skills or the tools to do anything much more than that.
The pool is only 11 x 16 x 6 feet in size.
I would be grateful for any advice. I don't want to buy a replacement all-in-one pump/filter/skimmer/ladder.
