I just had a brand new pool built, and I'm confused about how they plumbed it. On the suction side, there's a 3-way valve that controls pool/spa with a 2-way valve on the skimmer and a 2-way on the pool drain. That makes sense to me. On the pressure side, there's a 3-way for the pool/spa with a 2-way on the spa jets and a 2-way on the bubblers. The spa jets and bubblers are on the same return. The picture below is my return plumbing. Left to right is pool, bubblers, spa.
https://www.dropbox.com/s/hzailt3b1wic1jk/Screen%20Shot%202018-04-06%20at%2011.06.09%20AM.png?dl=0
I'm not sure why they put the bubblers and spa jets on the same return. Maybe it's so I can run the spillover and bubblers at the same time, which makes for nice water noise. But I'm confused about a few things:
1. If I have it in spillover mode and I open the bubbler valve, pressure on the pump goes UP instead of down. How is that possible? I'm opening up two more pipes, so resistance should drop - simple physics.
2. If I open both spa and bubbler valves, the bubblers get no pressure. As in zero - no water flow at all. It all goes to the spa. I have 8 spa jets and 2 bubblers, so I would expect the bubblers to get 20% of the water flow. To get the bubblers to activate, I have to slightly close the spa valve - 1 or 2 steps. When I do that, the bubblers get a little bit of flow but the spa jets stop completely. If I close the spa valve all the way, the bubblers turn into fountains - that part makes sense. But why am I not seeing a proportional amount of water flow to the spa jets if I close it partially? And why am I not seeing 20% of the water flow going to the bubblers when they're both open?
Similarly on the pool side, if I open the pool drain and skimmer at the same time, pressure goes up and the pump somehow sucks in air. Am I somehow creating backflow on the return valves?
