I have a robotic vacuum, but it doesn't do a good job in the corners and on the walls. Would somebody please recommend a set for manual vacuuming? I am assuming I would need a hose, a pole, and a set of brushes/heads.
Can you not brush the areas the robot does not get to and let the robot pick it up from the main pool area? That is what I do. I have a hose and wheeled vac head that has not seen use since 2016.
Same here. I just sweep the steps and the benches my vac doesn't clean, down to the bottom. The vac gets it from there... Try that first. Setting up and using a manual vac is a real pain...
