OK:
For: 21 foot AGP (Cornelius).
I rented sod cutter and got rid of sod in area and 18" past where pool will go.
Got ground as level as possible. Brought in a bunch of crusher fines (had to use 3-4" on one side of site to level).
Rented plate compactor and spend hours compacting the crusher fines.
NOW: I have site covered with tarps/black poly to keep heavy rain off.......BUT when I lift up tarps I see ants have got under there in some areas and there still is some single blades of grass here and there poking up through the CF base.
I bought some persanthamum derived insect killer (hoping not to use toxic chemicals that will leach into pool water).
WHAT should I do to go forward?
Plan is using heavy felt pad that our vendor supplied (I have to cut to size) on top of the crusher fine base under liner and foam cove). Will use river rock on the side we had to cut into yard (about 4" deep) and then crushed rock/pea gravel around the rest of pool
Should I lay down black polyethelene sheeting on top of CF base under frame and felt pad??????????
Thanks for any and all help here.
