Hi all,
Having some trouble I have not had before in 4 years of pool ownership.
We opened a month early this year, still cool/cold .... otherwise as normal.
During the winter I often have to pump water out, after heavy rain storms etc .... so typically CYA is zero/very low. This year on testing its between 50 and 60 (not sure ever been that high).
Perhaps may explain .... after opening I put pucs in the skimmer (as brand new chlorine continues not to work) .... which I did last summer, with zero issues. I tested fe times, and chlorine is really high .... with minimal pucs (3) ... again, nothing different to last year. Chlorine has been been around 8 .... and zero cc.
Which leads to .... I keep getting recurring algae? .... light sand color algae on the floor of the pool ..... I vacuum and brush, and literally within a few hours its back!
So, I have high chlorine levels, and this sandy colored algae.
Any help would be appreciated.
Thank you
Chlorine 8
cc 0
TA 120
CYA 50-60
pH 7
Thank you
Chlorine 8
cc 0
TA 120
CYA 50-60
pH 7
