Please guide me
Lemonhead
101
Middletown NY-211
13,000 gallon round , sand filter , above ground vinyl liner .
Fc 4
Cc 0
Ph 8.2
Alkiliinity 90
Cya 40
Calcium/hardness 150
Phosphate 550
I put in half a box of borax mule and 4 hours later this was the test results . I’m still learning here but I love this site . Seems the ph is high and the alkalinity is low. Which order should I correct these in ? And advice on the phosphate too please . Thanks guys
Texas Splash
33,613
Fiberglass
CircuPool RJ-45 Plus
The pH is high, but the TA is fine. How did you test your water? Your sig shows TF-100 but you included a phosphate result.
Also, how does the water look?
YippeeSkippy
17,620
Evans, Georgia
First I need to ask you WHY you wer putting Borax in your pool- what were you trying to raise, the TA or the pH?
Did you get these results from your own TF-100 or the Pool Store?
How do you chlorinate you pool? Liquid, granular or pucks? Chemical name and brand if you know it please.
Do you have Muriatic Acid? That's what you're going to use to lower your pH. It may also lower your TA a bit. Not a bad thing, but 90 can be ok.
PoolMath tells me that 16 ounces of 31% Muriatic Acid should take you down to 7.6 pH. If it doesn't (and give it a good hour with the pump on) it means you may be far above 8.2 but the tester tops out at that. Just repeat the 16 ounces.
Don't worry about the TA dropping, MA does that. A high TA will pull pH up, while a lower TA (say 60) might help slow a pH rise up so fast.
For Future Reference:
Maddie :bounce:
YippeeSkippy
17,620
Evans, Georgia
Dang Pat... I was typing away knowing i'd get a first response in for this poster and you beat me to the punch. I need to type faster and with fewer mistakes. :brickwall:
  • Haha
Reactions: Texas Splash
Lemonhead
101
Middletown NY-211
Had a tf-100 last year. I was late opening the pool this year . I need to order a new kit . The water looked fine. It’s been a week since removing cover . I just thought the ph was low so I dumped in the borax mule . I still had the left over chlorine and ph test drops from the blue case the old test kit came with. Can the phosphate reading be high from the borax ? Is it concerning? I got it tested from a pool store that puts the water into a cartridge and does a fancy test
Lemonhead
101
Middletown NY-211
Maddie :bounce:
I thought it would raise both . I thought ta and ph were low
Texas Splash
33,613
Fiberglass
If you still have the pH viewing (red drops) tester, I would just use that and some muriatic acid to lower the pH down to about 7.5. Also keep the FC elevated around the 5 ppm range until you can get some refills for your TF-100. I wouldn't do anything else at the moment. You can ignore phosphates.
Lemonhead
101
Middletown NY-211
I’ll order test ASAP. I miss it actually. Will phosphates go away naturally or are they just not a concern ? Pool guy tried selling me remover but I knew better to come here first
setsailsoon
4,281
Palm City/FL
CircuPool RJ-30 Plus
LH,
Welcome back from last year! Pat and Maddie have your back with expert advice. You will have your results right on the money very quickly with their advice. One year old TF 100 reagents are probably a lot better than pool store results. Remember we sell absolutely nothing. So advice here is never compromised by desire to sell you something.
Chris
YippeeSkippy
17,620
Evans, Georgia
<----TFPer hearing their phosphates are only 900!
Yeah, ignore phosphates. Waste of money at this time, especially the weak ones Leslies pushes on folks.
Reactions: setsailsoon
setsailsoon
4,281
Palm City/FL
Phosphates illustrate the point I make often that it's important to get advice from people that are not conflicted by trying to sell you something. TFP sells nothing.
TFP Method ====> Don't worry about phosphates====> no extra cost=====> Great looking pool!
Pool Store Method =====> phosphate paranoia=====>$59/bottle=====> pool has filter problems
