Plastic or stainless steel sleeve anchors for cement???
Wadeod
100
0
Granger, In
#1
Looking to put either 4” or 6” plastic or stainless steel sleeves around pool in cement for volleyball net and to hold umbrellas. Any suggestions on length and material for cold indiana? My gut tells me 6” of stainless ??
And I should say only the plastic anchor comes in 6” and tightens with wedge by screwing it tighter or looser. Looks like the steel one doesn’t tighten or loosen. Just 1.9” hole for my big umbrella
CJadamec
2,192
0
Quaker Hill, CT
#4
High quality brass would be my first choice as well, stainless would be my second choice.
Get a thread protector to protect the anchor threads when it's not in use. Typically a plastic threaded plug that keeps the hole clean.
CJadamec
2,192
0
Quaker Hill, CT
#6
Depends on how much you like brass and how much money you want to spend. Good quality brass will last for a very long time.
As for why I would choose a brass anchor, its because it will have a coarser thread cut deeper into the material giving you a thread more forgiving to small sand and debris that will get in the anchor hole. Over time, with repeated use, or from over torqueing stainless threads have a tendency to strip and gaul. From a corrosion standpoint in that application good quality brass and good quality stainless will be similar.
