Hey,
The manufacturer of my quartz finish (Pre Marbelite Mix Marquis) says this on their warranty page:
"Afterwards [start-up], balance the pool water to the above noted water parameters. Check the pH several times per week for the first few weeks and add pool acid pre-diluted to the deep end of the pool to lower the pH to 7.0-7.2 range or lower if needed. NEVER allow the pH to rise above 7.6 during the first 30 days. Brush the pool daily for the first 30 days, then as needed."
I know the installers did an acid wash before filling and a lot of aggregate is exposed. Should I run my pH that low when it pushes the CSI into the negative range?
Mike
Mike
