Plaster damage
Shaf
5
Missouri City
Someone threw some cal hypo into the pool (gunite/white plaster/chlorine 29k gallons) and it ate away some plaster
bad is this? I wasn’t planning on replastetring until next year. Does this change my timeline
I am generally on top of my pool chemistries.
Shaf
5
Missouri City
Also, during the initial build you could see areas that were darker, ie the gunite was showing through. I felt this was a problem but my builder assured me it was normal. For the record, white plaster should be white and opaque, and gunite should not be seen through a thin layer, right?
ajw22
20,477
Northern NJ
How old is your plaster?
White plaster can turn gray that you may think is the gunite.
@onBalance thoughts?
Shaf
5
Missouri City
Plaster is 6 years old
And absolutely sure as I saw them toss it in and didn't think it wouldn't dissolve, though it was on the steps
I did check all my chem levels. pH was a bit high, 7.9, TA was low at 40, everything else was within normal range. I've been having a hard time keeping TA where I need it this season
sktn77a
1,909
Chapel Hill, NC
Unusual for a single throw of cal-hypo to burn through the plaster. It could be mild staining that was oxidized to a darker color by the chlorine. Try a little ascorbic acid on the grey discoloration.
