Pitting in new plaster
Tenab
162
NE Texas
Is pitting like this common in new plaster? It's mainly around the tile installs. (I'm about to do AA and do not want to cause more damage)108765
pooldv
Platinum Supporter
Moderator Emeritus
Aug 10, 2012
25,412
FL panhandle
Some pitting is common in plaster. Ascorbic acid will not create any additional pitting problems.
Reactions: Tenab
Tenab
162
NE Texas
That isn't pitting. Those holes are from the spikes the plaster guys wore during the install... sloppy
Yikes! They had sponges on toward the finish. We have mostly smooth plaster I believe considering this builder, these few spots are bearable. The stains could have been avoided though. ??‍♀
Tenab
162
NE Texas
It is better to wait 30 days before using the robot.
Oh dear! I read several places 2 weeks. There is so much my little hand held isn't picking up. The lower drain doesn't seem to have enough suction to pull it out even when I brush it down there. Any suggestions?
bdavis466
Platinum Supporter
Aug 4, 2014
5,529
San Clemente, CA
The robot won't hurt anything. You're fine within a few days after having the plaster done.
I think Danny is talking about the type of robot for his own personal use in the bedroom?
Reactions: pooldv
Tenab
162
NE Texas
I held off on the robot, bought a hose and did a manual vac through skimmer.
The robot seems old tech to me and I'm going to ask to upgrade it. I don't mind paying a bit more to get something I might be happy with.
rhthompson
Active member
Apr 4, 2018
28
Knoxville
i see very similar small pits around tiles on my pool after replaster. If caused by worker's spikes, why just around the tiles and not elsewhere? I've assumed it results somehow from the process of pushing tiles into wet plaster
Reactions: Tenab
Tenab
162
NE Texas
I think you are right. It seems to be mainly the tiles and corners. I think it dries so fast they don't get it worked well in those areas in some cases.
Just my conclusion
