Phosphate Levels
RushPool
3
Stow, Ohio
We have a 20,000 gallon in ground liner pool with DE filtration. Our water chemistry is fine with everything in normal ranges. Testing for Phosphates gives a reading of over 2.5 PPM (2500 ppb) Is this something we should be concerned about or does it not really matter. Not sure where the phosphate is coming from. We have trees near the pool, but keep the pool clean and vacuum every day to keep dirt and debris out. Do we need to take measures to reduce the phosphate level?
RushPool
3
Stow, Ohio
Thanks for the welcome. The pool chemistry is stable and we have no problems with our normal chemistry. I appreciate the quick response and will look through the reference you provided.
JoyfulNoise
Platinum Supporter
May 23, 2015
16,132
You should check with your municipal supplier or test your tap water for phosphates. Many municipal water districts add orthophosphate to the supply water to control corrosion especially if your water district has old cast iron water pipes with lead joints.
If your water supplier is using phosphates for corrosion control, then treating the pool water for phosphates is a losing battle.
Reactions: MyAZPool
JoyfulNoise
Platinum Supporter
May 23, 2015
16,132
Matt, wouldn't it be more accurate to say it will be an ongoing battle?
I suppose....some would argue that if phosphates are being continually added to the water, then it's a losing situation in terms of money and ease of care so you should just ignore the phosphates rather than spend the money to constantly treat them. I would be more on the side of treating for phosphates as long as it doesn't cost too much. Right now, I typically treat my pool once per season and that's fine by me. If I had to treat for phosphates every month, then I'd rather just spend more money on chlorine and not worry about it....."to each his own" as they say...or maybe that should be "pick your poison..."
Reactions: Rollercoastr
Rollercoastr
867
West Bloomfield, MI
Oh, if it were a monthly issue, I totally agree that it would fall into the "losing battle" category!
I looked-up my city water tests last year and I remember thinking that the added phosphates were significant, but maybe not - I didn't compare it to any other water supplies.
Similar threads
