I tested my water yesterday, and the PH was so low it wouldn’t match a color on the sample tube. I kept adding the base to it, and finally got it close to the Lowe limit (20 drops). Could it really be this
Yes, we need to see the TA, but what do you use for chlorine?Thanks!
I didn’t test TA yet because the PH was so low. I should have?
You need to test CYA while you are at it, those tabs are also almost half CYA/Stabilizer.Oh no! Should I be using something else for chlorine? I have the Taylor K-2006 kit. I am at work, but will test the TA as soon as I get home.
Before you add the baking soda, post what your results are along with the size of your pool. While you are testing, give us a full testSo, I’m going to stop using the tablets, and only use bleach for chlorine from now on. I’m also going to get some baking soda on my way home, and test the TA and CYA when I get there. Thank y’all so much!
