Ph test ?
mguzzy
What test are you doing?
FAS/DPD would give .5 ppm
You could use a pH meter, which will give you a pH accurate to 2 decimal points. You also have to calibrate a meter regularly with pH standards and keep the bulb moist, or it won't measure accurately.
@mguzzy FAS-DPD measures FC and CC, not pH.
Duh.. Of course that's what I get for trying to multi-task. And post from my phone..
What I was going to say is before my mind made no sense ... if the FC is over 10 the pH is hard to read.. so use the FAS/DPD to see what the FC is.
revitup
432
Pawleys Island, SC
Fiberglass
Hayward Aqua Rite (T-15)
PH test was the only test I truly hated doing. A PH meter solved that.
