Hello, I am new also with a 3000 gal spool. I'm considering Borates and can see from the pool calculator the amount of acid required to lower pH levels is a little over double than without borates. My pool being small and having aeration jets tends to rise in ph relatively quickly. If I add borates to the pool will there also be a buffering affect on rising pH when the fountain and jets are on? As it is now its very hard to keep in pH balance below 7.5 to 7.8. Thank You
Richard
Richard
