Disregard pool in signature:
friend's pool.
The pool is 4 years old, vinyl, IG 20' X42' at approx 35000 gallons. 1.5 hp pump coupled with a Jandy CV460 cartridge filter,Delta E-40 Ultraviolet Sanitizer/Clarifier System, Raypack PR406AENC heater, automatic pool cover and a robot. No SWG.
For the test results, here are the opening numbers:
4/19/2019 water temp 68 deg
FC- 0
CC-.5
PH-7.5
TA-120
CH-200
CYA-0
4/26/2019 What I've done since: water tem. 82 deg
FC- 6+ (as I wasn't home to slam so gave it some chlorine not to lose ground)
CC-.5
PH-6.8
CYA- coming up
water is crystal clear now, brushed and vacuumed
Added 7 lbs dry stabilizer and will need approx another 2 lbs to achieve my CYA goal of 30.
Slammed and will do the OLCT hopefully today . Will check all my numbers prior to the slam.
Question:
What do I use to bring the PH up and would it be contingent where my TA is at now. I have "20 mule team Borax" for the job but am I on target.
Thanks in advance, Allan
friend's pool.
FC- 0
CC-.5
PH-7.5
TA-120
CH-200
CYA-0
CC-.5
PH-6.8
CYA- coming up
Question:
