drewwestrick
That helps a lot. I didn’t realize low CYA played into PH stability that way. I’ve been slowly letting CYA rise as it’s easier to add than subtract CYA. Sounds like as raise CYA and TA naturally comes down as I continue to add acid, I will probably see less PH rise and/ or find a stable PH.
