Looking for some advice on finding a leak. IG Pebble-sheen pool with a spa. I noticed earlier in the year that it seemed like my auto filler was not keeping up with evaporation. After playing around with it, I realized the pool was leaking water.
If I shut everything off, and let it sit overnight, the pool drops by 1". The Spa level does not change. I let it sit for over a day and the water level dropped 1" below the skimmer inlet. Today I got in the pool with a syringe and leak dye. Checked all returns, drains, and light fixtures and the dye did not indicate any leaks. Scanned every nook and surface of the pool for any physical signs of damage with nothing detected.
I would think that with the water 1" below the skimmer entrance, that the skimmer boxes and skimmer return lines are good. I'm going to pull the light fixtures tomorrow and check with dye inside the housings, but doubting I will find much since no dye pulled in around them today when I checked.
Any other tips or tricks for finding where my water is going?
