& to Dirk again, it’s well worth having Mechanicals & structures (throughout the property) inspected by specialists.
Contaminated sand? What does that mean?
How did they determine that?
The “contaminated sand in gunite†is bogus. How could he possible know anything about the gunite which is beneath the plaster?? Unless the inspector drilled a core sample out of the pool shell and did some kind of analysis, the “contaminated sand†comment is nothing but pure speculation (and baloney). That pool shell is most likely cracked and if it is cracked it’s from sub-soil movement. The only definitive way to know is to drain the pool, chip away the affected plaster and inspect the shell.
Any idea if the pool leaks? A crack in the shell doesn’t necessarily create a leak per se but further expansion of the crack can.
that’s true, I will have to pay for the deeper inspection, however they recommended pool finish to be repaired and restored but is this more of a cosmetic thing they are implying????
maybe I will have another company come out and just have to pay myself
I swore I was going to walk away from this thread, as my comments, I'm sure, are not appreciated. But I can't help myself...
I'm looking around here for a hat that will not taste too bad, 'cause I will eat it if I'm wrong (and I am absolutely no expert in pool construction). We are all hoping for the best for this couple, but come on folks! What? Did Moses the water beetle raise his little legs and part the pebble for his little beetle-people to cross the entire width of the pool, right between the shallow and deep end? How could Pebble Tec possibly do that? Has anyone ever seen Pebble Tec do that? (Why don't you call Pebble Tec and ask? That'd be free! Send them the pictures. Seriously. See what they say.) THAT IS A CRACKED SHELL. Plain as day. They've got water leaking into the gunite, or will have, and for how long? Probably eating away at the rebar as we speak. Why didn't that worthless pool inspector start a proper leak test?!? I'll eat the brim if that pool is holding water.
Back to my lack of knowledge about pool construction... The pool is dropping into the soil. How can that soil now be properly compacted with a pool sitting on it?!? Drill through it? Pump concrete under it somehow? Is there any way now to even properly test that soil, UNDER A POOL, that would determine if the sinking has stopped?! The pebble is a $9K repair minimum. That's a known figure. How could repairing the shell and fixing the soil problem in such a way that would guarantee no reoccurrence of the settling be any less? It has to be more. Way more. And where are you going to find a contractor that would attempt that? Even if you could, he wouldn't take on a liability-prone job like that for a bargain. No way. I'm thinking another 10, maybe, but I'm always off by at least double when I guess about construction costs. And you won't have contractors lining up to get at this job. You just won't. They want to build pools. They know how to do that. They don't want to fix pools. Somebody else's problem. And certainly not one with this kind of unknowns! If you find one, he'll be able to charge whatever he wants. And no matter what bid you get, this is just primed for that cliched scenario: half way into a 30K+ (or whatever) repair and the contractor comes to you with "Gee, real sorry, we just ran into [fill in the blank] and we're gonna need another [fill in the blank check] to fix it. (Hint, it's not going to be another few hundred dollars.)
Would you buy this house if it didn't have a pool? Is it that special? Is that .3 acre so hard to find that you're willing to spend another $20K, $30K, $50K+ over it's value to deal with this pool? Either to fix it, replace it, or fill it? Or are you just going to patch that crack until you want to sell it later? Do you think the next buyer is going to be as sympathetic as you're being to the seller? Is this your starter home? 'cause even without the pool issue you're looking at living there a long time before you could flip it. With the potential pool expense, you might never get any equity back. Are you just starting your lives together? Or is this your retirement home?
I don't know the first thing about you, or your plan. I can only say: I'm old, I'd never buy this property as my last house. My daughter is young, I'd never let her buy it as her first house.
I can't argue the prudence of getting a proper inspection by an engineer. But depending on what that might cost, I'd be tempted to go another way first. I'd first see if I could get a contractor to even look at the job (that's free), and provide an estimate (also free) for repairing a cracked shell, a contractor that would guarantee he could stop the settling. You've got a cracked shell. You don't need to pay to have someone tell you that (That is pure speculation. But tell me I'm wrong!). The more important thing to know before you buy, before you spend thousands on inspections: is there anyone willing to fix it, and what would they charge? Sure, an engineering firm might be able to tell you what needs to be done to fix the problem, but if you can't get anyone to do the work, for anywhere near what would make any sort of financial sense, then what is the point in throwing more money into inspections. Unless the property is so special that you're willing to deal with that pool to live there. And deal with that pool when you want to sell. Maybe after spending a grand or two with the engineering firm they'll tell you "Oh, that's nothing. It's fine, just pour some goop into the crack and you're good." Yah, that could happen.
I am talking out of my ..., for sure. Somebody tell me I'm wrong. You won't hurt my feelings. I am praying I am wrong!! Again, I know this is not what you came here for, but I just can't in good conscious say nothing.
PS. It does appear to have good bones. RV garage. Stucco. Tile roof. Big yard. All good. But you're about to make a decision that could affect your quality of life for the next several decades. Please be smart about it. At the very least, do all the free stuff first, before you throw more money at this. That's all I'm sayin'...
