Pentair Temperature Sensors
mbender
2
Poolesville, MD
Hi - we just had our pool installed late last summer. At the time both the air and water temperatures worked on the Pentair panel and our phone app. I am not sure if they did something when they closed the pool or skipped something when they opened the pool but now neither temperature reads on the panel or app. Is there something we need to do to "turn this on"? Thanks!
Jimrahbe
19,095
Bedford, TX
M,
They should just work!!! The air temp just hangs down below the panel..
Odd, what else does not work?
I'd take a quick look behind the main panel and make sure everything is connected... Similar to this.. The temp sensors are in the lower right of the board.
mbender
2
Poolesville, MD
The sensor definitely hangs down. I will ask my hubby about looking under behind the circuit board but not sure how they would have gotten disconnected over the winter. As you can see on the app, nothing is registering (nothing registers at the panel either though).
