Pentair SWG IC40 no lights
Sherjam11
2
South Carolina
Moved from here.
Hello @Jimrahbe , I just encountered the same issue about a week ago. Pentair pool system, IC40 Chlorine Generation, No lights at all, tried to reset....nothing. Measured voltage DC 27.8 volts in a EasyTouch 8, where the IC40 is connected. Stamping on board indicates 39.0VDC. What should the correct voltage be, either board is bad or the Transformer is bad. All fuses are good or either reset. Any thoughts.
