Pentair Superflo VS with SolarTouch
RicksterB
3
Corrales, NM
Moved from HERE
Realize that this is an old post...I'm looking to do the same thing ...Solartouch with a Superflo VS. I currently have a new Superflo VS and a GL=235 controller. I don't like the GL-235 since it does not have a temp display and it does not communicate with my pump...this controller and solar system was just installed, wish I had known about the GL-235 prior then I could have asked the installed to use a Solartouch.
Topher55 - has everything been working fine? Looking at pulling the trigger on ordering a Solartouch. Are there any newer or better options out there?
Thanks!
-Rick
mknauss
47,912
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Welcome to the forum!
How new of a Superflo VS pump do you have? If manufactured since 11/2020 it can use RS485 control with certain Pentair automation systems. You will need to check if the Solartouch is one of them.
I suggest you read ABC's of Pool Water Chemistry.
RicksterB
3
Corrales, NM
I connected everything yesterday as stated in Jimrahbe's post on Feb 27,2017 and everything works great...connecting to the booster pump relay, using the red 5v wire and the yellow speed 2 control. When the solar turns on it turns on speed 2 of the pump. When it turns off, the pump goes back to it's programmed schedule.
Thanks to everyone on the old 2017 posts!
