Pentair SLConfig thinks my Solar is a heat pump and won't allow me to change it
Ranger519v
2
California
My Pentair Screenlogic settings were once correct but got wiped out. I've got everything set up but when in SLConfig->Other Equipment->Equipment Configuration (Pool) and I enable "Solar Present", it also enables "Solar is a heat pump". I can disable "Solar is a heat pump" but after a Save, it "Solar is a heat pump" is still enabled. I must be doing something wrong but I don't have a heat pump. Any clues?
Try setting this at the outdoor panel, bypassing ScreenLogic.
Menu > Settings > Solar > Heat Pump: No
I don't have an outdoor panel that has the above Menu options (I have a System i7+3).
However, I was able to use SL Config on my wife's iphone to disable "Solar is a Heat Pump" and after hitting Save, the change stuck. I was using an Android so this appears to be a defect in their Android app. It's not the first one that has bit me so I should have known.
Reactions: Jimrahbe
