Pentair Minimax CH 200m
Tony Lanz
2
Michigan
Hi I opened the pool the other day and the pilot lit but heater would not ignite. I was messing with it and disconnected one of the yellow wires on the millivolt probe thermistor that connects to the I suppose mother board and it fired up. It stayed lit but only shut off when the pool pump shut off. I ordered a new millivolt probe and replaced it. Well that didn't solve my problem but even worse when I disconnect one of the yellow wires now it don't light. Any ideas tips or suggestions would be great.
swamprat69
271
Las Vegas, NV
This should be the manual for your heater; Electrical; Millivolt Wiring Diagram - Pentair Pool Products MiniMax CH Operation & Installation Manual [Page 17] | ManualsLib. Don't know where you disconnected and reconnected wires, but if you look at the wiring diagram on page 17 you will see that the only 2 wires coming from the thermopile ( the part that sits in the pilot flame ) both connect to the gas valve. I do not see a yellow wire listed ( may be a white wire that has discolored from age).
Tony Lanz
2
Michigan
It was the wire from the millivolt probe thermistor which I believe senses the water flow and connects to the circuit board. Thats the item I changed and unplugged when I was messing with it just to see if wires had been corroded. So I thought that had gone bad.
