Pentair Mastertemp 400 - Not igniting No errors
delyles
19
Houston Texas
I have a Mastertemp 400 that is not igniting. At startup the blower does not turn on. No errors on LED Panel or on board. No lights on ICM.
I direct wired the blower to ICM and the blower does power up, but still no ignition.
The article I was following stated if blower works with direct wiring, then the issues is either bad ICM or bad control board. Anyone know how I can test to figure out if my problem is the ICM or the Control board?
delyles
19
Houston Texas
Not sure on gas pressure, how can I determine that? It is propane and we did just have the tank top off recently (heater issue started after tank filled). Could that have anything to do with it?
the light on the Fenwal does not flash at any point
JamesW
28,253
If you have a call for heat, the AFS should light up if the blower is not on.
If no AFS error light, then you probably do not have a call for heat.
delyles
19
Houston Texas
I dont get a AFS or any other lights, blower does not come on. So no call for heat...is that a control board or ICM issue or something else I need to be looking at?
delyles
19
Houston Texas
You sure you have proper gas pressures?
The heater NG or propane?
Check if the LED is flashing on the Fenwal box in the electrical area when it does not start.
More on the Fenwal at Heater Flame Sensing - Further Reading
ajw22
29,067
Northern NJ
Pentair Intellichlor IC-60
If your heater connected to automation?
Do you have a connection to the "firemans switch"?
Please create your signature with details of your pool and equipment. IT helps us help you better.
ajw22
29,067
Northern NJ
If you are not getting the air blower running or an AFS error then you are not getting to the gas and ignition stage.
delyles
19
Houston Texas
I would agree with that, definitely no hint of gas or any noise of gas. Is it possible the Propane company coming out to fill the propane tank caused issues with gas flow to heater? I dont have a clue how to test if heater is getting gas.
ajw22
29,067
Northern NJ
I can't clearly see what wires are connected to the two firemans switch connections.
Let's have you put the heater into local control to rule out an EasyTouch problem. Disconnect the two wires leading to the ET and jumper the firemans switch connections to restore local control. Then see if the heater turns on using its control keypad.
It looks like you have the yellow jumper wire with clips on the end you can slide onto the connectors on the bottom of the cabinet.
Reactions: setsailsoon
delyles
19
Houston Texas
ok, tried that, removed ET wires, jumped firemans switch with the yellow jumper wire, ran spa from control panel in Service mode. Still same issue, heating light blinks for 20-30 seconds, blower does not run, then service heater light on. no other error codes or lights on control board or ICM.
ajw22
29,067
Northern NJ
OK, leave it that way. It makes it easier working on the heater.
Flip over the board and show us a pic of the diagnostic LEDs when the SERVICE HEATER is on.
@ps0303
JamesW
28,253
That circuit board looks like it is in bad shape.
How old is the heater?
Is water getting on the circuit board?
It looks like the Membrane pad is cracked in a few places?
ajw22
29,067
Northern NJ
Show us the entire board. Your board looks old with the component layout very different then the latest board @JamesW posted.
delyles
19
Houston Texas
I'll get some better pictures tomorrow, I dont think what looks like water is actually water. There was no sign of water on the board earlier when I had the box opened up. I think that may be blistering....that looks like water with the flash on my phone.
The heater is 5 years old. It did go through the Texas deep freeze last winter.
I've attached a few more photos I took earlier today of the board.
