Pentair Mastertemp 400 leak
crashxx
85
Oklahoma
I have a Pentair Mastertemp 400 that's leaking. It looked like the water manifold was leaking so I replaced all the O rings. Now I have water dripping out of the white plastic air inlet. Can anyone tell me what I need to do to fix this? Thank you all and Merry Christmas to everyone!
ajw22
33,361
Northern NJ
Pentair Intellichlor IC-60
The heat exchanger is probably corroded.
All the water is sealed in the heat exchanger. Any water internal in the burner can is likely a heat exchanger leak.
crashxx
85
Oklahoma
I use bleach, injected into the return with a pump down stream from all equipment. We have an automatic cover so the pool always stays closed. I generally keep the chlorine levels low, or at least I thought I did.
mknauss
47,173
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
The exchanger is typically half or more the cost of a new heater. So a new heater would be a better choice.
ajw22
33,361
Northern NJ
