- Jan 24, 2020
- 194
- Plaster
- Pentair Intellichlor IC-60
Pool is finished and we are trying to understand the behavior of the Pentair Mastertemp 400 with our IntelliCenter i10PS.
We enable spa which turns on heater trying to get to 99 degrees from the 63 degrees it is currently at... After a while the system turns itself off..
When I go to the heater the heater panel is off and if I press on I see this.. Our Intellicenter says it is 86 degrees and set to 99... when I check out the heater is the heater telling me the spa temp is 101 and I set to 99... ?
Little confused on what is going on...
Heater panel when I notice the heater turns off...
Pentair App status when the heater is off
