Pentair Master MasterTemp 128 r=5 Code
ShallowWater
20
Riverside, Ca
Now don't I feel STOOPID!
The way this was plumbed you have to step over the gas line (rigid pipe at least) to get to the Jandy Control Panel. Apparently I recently nudged the gas shut off valve to a half closed position so it was probably getting insufficient gas to ignite. At any rate, problem solved for now and something else for which to be on the watch.
ajw22
18,067
Northern NJ
Gas valve turned off a lot. And when I ask if the gas is on I always get an Of course reply. Check the gas line was going to be my next suggestion after the blower.
:goodjob:
JamesW
19,337
Note: Normal boot up is 888, 128 and then rX where X is the software revision number.
The numbers are displayed briefly and then go to water temperature.
Reactions: ShallowWater
