Pentair Legend cleaner basket screen in wall connection
scatesrl
1
Texas
I have a Pentiar Legend cleaner and the Basket Screen that is in the Wall Connection Assy keeps plugging up as my
pool gets a lot of sand/rock dust off the flagstone rock when the waterfall runs. Do I Have to keep this screen installed?
ajw22
19,303
Northern NJ
Welcome to TFP.
You have a pressure cleaner. Any debris coming out of the wall connection is coming from your filter. Since you don’t have details of your pool in your signature we don’t know what type of filter you have. You should figure out why your filter is letting that stuff through.
If you remove the screen then the debris will flow into the water pipes that power your cleaner, clog it up, and become more difficult to clean.
YippeeSkippy
14,429
Evans, Georgia
Let me see if I understand... your rock waterfall drops sand and bits of rock into the pool, which then get picked up by the cleaner. The cleaner sucks directly into the wall outlet but the screen there clogs with this sand and rock debris. Right?
If there is any chance of large debris passing thru your vac into the pipes..... you risk a clog. Otherwise anything I imagine larger that goes thru would get caught in your pump basket back at the equipment pad.
Perhaps the real solution is to somehow seal the rock fountain? Keep it from disintegrating..... THAT might be the real answer here.
Maddie :flower:
ajw22
19,303
Northern NJ
Maddie, the Pentair Legend is a pressure side cleaner with a bag, not a vacuum.
